[Purchase Help Need] Range Extender/Booster or ai-mesh for Asus Tuf-AX5400
princeoo7
On a Journey called Life :P
Keymaster
I stay in an around 1000sqft flat and there are around 3 to 4 walls from my room to main hall room where the range don't reach if not sitting in straight in line to door. In rest of the main hall, no range at all. also all other devices loose wifi even if we in range. so basically to use wifi, one needs to be in my room or I have to keep the door open and one needs to sit in front of that door.
I cannot extend Ethernet cable to other rooms. Can we create a mesh via wifi itself? or a range booster/extender is an solution.
My router: Asus Tuf-AX5400
