bobbyprajan
I want to use a push pull fan arrangement for my cpu cooler. Both fans are identical make and model. However i can power only 1 fan from the CPU Fan header which is a 4 pin type (PWM).
Where do i connect the other fan to ?
When they are spinning at different speeds will it affect the airflow negatively ?
What is the recommended setup in such a scenario ?
The motherboard is Asus M4A785TD-V-EVO, Processor is Phenom II 965 BE, CPU Cooler is CM Hyper 212 and fans are CM 120 mm 69 CFM fans
