Hey guys,
I recently purchased a Hyper TX3 cooler and a CM 430 Elite from SMC.
So I go about installing the computer from scratch with a new RMA'ed Intel DG33 Motherboard. I install a second generic fan on the TX3 blowing air towards the heatsink (Stupid I know). The case is as it came, with one front 120mm fan blowing air over the Hard Drives. It gave me idle temperatures of around 46C and under load gave me around 63C. I used the thermal compound that came with the heatsink. I also used this thermal compound on a buddies two year old computer which we cleaned and then reinstalled. So basically I'm out of the Cooler Master thermal compound.
Day before yesterday I realised my mistake about putting the second fan towards the heatsink. It just came out of the blue when I was riding back home from college. Mind you I've done many PC installs before, it's just that I have been installing computers for the 'normal' people and was oblivious to the existence of all these awesome products. As a heatsink thermal compound I've always used the Nepali Heatsink Thermal Compound. It's worked for me since the average person here never buys anything better than a Core2Duo and that is in general a cool running processor. Anyways I go to the computer store around town looking for a good thermal paste,and none of them have it..I mean none of the shops out of the dozen I visited around town had any at all. Then I asked a few of shops what they used for thermal conductivity between the Processor and Heatsink and they presented to me the same small box with a red cap labeled Nepali Heatsink Thermal Compound. I smiled to myself and figured that'll have to do and bought one for 40/-. I came back home,removed the motherboard, cleaned the processor and heatsink with alcohol and applied the Nepali Heatsink Thermal Compound using the line method,which I use for all Core2 Series processors.
I boot up the computer,and see the idle temps at 42C and am thrilled,also my 8500GT GPU idles at 55C which is extremely cool considering that it is a Silent Version from Asus. My motherboard is also running cooler at 40C. I decide to run a stability test using Everest and check the termperatures using Speed Fan and HWMonitor. I start the test and observe the temps. My heart sank when I saw the CPU touching 75C underload after around 4 minutes. Isn't that insanely high? So what's the problem here? Is it my thermal compound? If so what alternatives do I have? I feel paying 50-60/- as shipping for a 200/- rupee product is rather stupid. Anyways I'm going to include a few snapshots and then a brief summary for people who can't be arsed to read the whole story. =P
Brief Summary :- ( Speed Fan Temps!)
Q6600 with Hyper TX3 and Cooler Master Thermal Compound with a second fan blowing air towards the heatsink (Stupid!, I know):-
Processor at Startup - 49C.
Idle - 52C.
Under Load - 65C.
Motherboard at Startup -43C, idle-43C, Underload - 47-48C.
Graphics Card at idle and startup - 65C, Underload - 78C.
Three HDD's - 36-38C.
Q6600 with Hyper TX3 and Nepali Heatsink Thermal Compound with the second fan blowing air away from the heatsink :-
Processor at Startup - 44C.
Idle-55C.
Under Load - 75-76C.
Motherboard at Startup -41C, idle - 44C, Underload - 46-47C.
Graphics Card at startup - 55C,idle- 64C, Underload - 67-68C.
Three HDD's :- 38C
Guys, after my expenditure of about 4.1k on Cabinet and the fan, I'm pretty much broke for this month. Until I get another request for assembling a computer or repairing something I'll be that way and I have no idea when that will be. I'll have to ask my mom for money which sucks, I simply hate asking for money, so unless it is completely certain to solve my problem I want to refrain from getting anything. That being said I had set aside 500/- to get a new 120mm case fan for the rear as exhaust but guess what!?,above 80 mm they have nothing here.
If you need any other info let me know. Also if you notice different applications report different temperatures which is extremely weird.
Anyways ,Thanks for reading, and if you read the whole thing, I have to tell you, You have a lot of patience. =D
System Specs.
I know the problems with the RAM, I have a 2GB stick @ 800Mhz returning from RMA in a few days.
Inside.
Load. ( 2nd Config using Nepali Thermal Compound)
Idle. (2nd Config)
Nepali Heatsink Thermal Compound. =P Taken with an E63,crappy quality.
Cheers.
Idle - 52C.
Under Load - 65C.
Idle-55C.
Three HDD's :- 38C
System Specs.
Inside.
Idle. (2nd Config)
Cheers.
