Radius Tru-Tune Ultra-light Aluminum Earbuds W/ Noise Isolation, iPhone Compatible -
sumchamp
Explorer
Feedback: +43 / =0 / -0
Radius Tru-Tune Ultra-light Aluminum Earbuds W/ Noise Isolation, iPhone Compatible - Matches 3G Blue Nano - RA-HP01BL
Radius Tru-Tune Ultra-light Aluminum Earbuds W/ Noise Isolation, iPhone Compatible - Matches 3G Blue Nano - RA-HP01BL - Buy.com
Radius TruTune earphones set a new standard for fashion and fidelity. From the satin aluminum casing to the sleek, soft cable, these Japanese-designed earphones are thoughtfully crafted inside and out throughout, so your music sounds as good as you look.
The Radius design is personified in the TruTune line of earphones. Blurring the lines between ‘sound gear’ and ‘fashion accessory’, TruTune is stylish, unpretentious and universally affordable. The available colors ensure a spot-on match for your music player or your aura.
Tech Specs
Dynamic Driver 10mm
Neodymium Magnet 9mm
Stereo Mini Plug 3.5mm
Mini extension 42â€
Frequency Response 20Hz-20kHz
Sensitivity (1KHz, 0.1V) 103dB
Impedance 16O
Chinese copy
available at dealextreme for $3.83:)
Has 300 reviews:O by the customers chk it out guyz.;)
H@cKer said:
Chinese copy
well, i had got the ones from dealextreme. they are not bad, but neither are the any gud. sounds a pretty bit harsh when compiared to ep 630. :P but then i am comparing a 4 dollar thing to 15 dollar one :P
G@d of w@r said:
This site ships only to US :( will order from dealextreme
rep me for showing u dealextreme link dude:bleh:
@bitsandpieces Any idea how long it takes for product shipped from dealextreme to reach our place
@sumchamp Ordering through kmd would get costlier for such low value product
I would readily go for the 630 even if they are priced at 15. Besides, Ebay makes them 12 lol :P
Besides it takes a loooooooong time for DE items to come.
usually dealextreme will take about two weeks for most products, though make it three to be on the safe side :)
shape of the mould n plastic must be same..but not the inner thing..oh cmon
you guys gone out of the mind, dont compare the sound by the looks of earbuds
