..:: Free Radical ::..
RadMTNL - An advanced usage monitoring tool for MTNL Delhi 749NU plan subscribers
RadMTNL v1.0.0.3
I am an MTNL Delhi 749NU plan subscriber and rely on register.mtnldelhi.in for checking my usage details.
infernalProteus' excellent DataFox unfortunately never worked for my ip range so I felt the need to code my own bandwidth monitoring tool. This Windows app borrows ideas from his excellent firefox extension.
Please note that this will only work for you if you are on the same plan and use register.mtnldelhi.in to check your usage details.
Just click the app, It will prompt you once for the username and password and save it to an .ini file.
The app reads your login details from the RadMTNL.ini file so if you entered a wrong password/username, just delete the ini file and reload the app.
The login details are only sent to register.mtnldelhi.in and are not stored/sent anywhere other than the ini file created.
It will tell you your usage in a gui.
It also shows the daily average target usage calculated by 1280 / the no. of days of that month (leap year correction not added) as both text (the daily target indicates the daily average+surplus) and a small black meter below the usage progress bar.
The plot graph function does exactly that. It saves and reads data from a month log. The algorithm only updates the log till the previous day but the graph will take into account your current usage.
For the time being I have only restricted the graphing function to the current month.
*Clicking anywhere on the graph will show a tootip of the day usage till that day.
I won't be responsible for any consequence of using this app.
Use at your own risk.
This is only an early release and I plan to add more functionality in the near future. Kindly post feedback if/not it works for you.
RadMTNL v1.0.0.3
