anmolbhard004
samsung is known for issues in washing machines I had a top load from them and I had to get the PCB changed twiceHad a Samsung front load which constantly gave issues. I would suggest sticking to conventional washing machines if no special use case for fully automatic ones.
What's wrong with your current Bosch Series 8?Guys recommend front load washing machine brands/ model 8-9Kg
LG does not have sealed tubs so future maintenance will be cheaper.I am confused between LG And Bosch
Any machine can develop drum issues if not cared for. LG has a slight edge here with a stronger drum support.have heard bosch has drum issues is it true?
What problems did you have with it?Had a Samsung front load which constantly gave issues.
Front loaders clean better than top loaders. I see no reason to recommend the latter any longerI would suggest sticking to conventional washing machines if no special use case for fully automatic ones.
mine series 8 is working perfectly, I need one for my sister's new homeWhat's wrong with your current Bosch Series 8?
How hard is her water?mine series 8 is working perfectly, I need one for my sister's new home
dont know much about kolkata water but assume the TDS Of a place near sea and using borewell waterHow hard is her water?
That's hard water then. Better to check the hardness periodically as this will have a bearing on descale frequency. Amazon sells total hardness kits. Don't use TDS as that doesn't measure water hardness.dont know much about kolkata water but assume the TDS Of a place near sea and using borewell water
