linuxtechie
Explorer
All,
As mentioned, I am looking for fans that can be run off the main AC. Am interested in two fans as am interested in doing PushNPull air flow.
Also let me know if its a better idea to use 120mm high CFM fans for this kind of setup. Will it consumes less watts as compared to running from AC mains.
The fans will be fitted on the wall of wooden enclosure, to be precise, on the right hand side. The lower fan will push air in, and the upper fan will push air out.
Forgot to mention: The case is all opened up, that is, without the side car. Also I am planning to push the air through filters. Hence please recommend filter as well, as its very very very dusty (due to construction going in neighborhood).
Thanks
~LT
~LT
Thanks
~LT
~LT
