Not sure, but i think there should be!!
Like an idle pc consumes less power than one at full load!!
U may use a 500W PSU but idle load maybe 100W and at full load maybe 350-400W, depending upon your config!!
Any electrical device is rated for max power consumed!!
So a TV consumes full load irrespective of what channel u watch!!
Fridge and AC will consume depending on how much you load the compressor, meaning the cooling required!!
A bulb rated 100w will consume 100W but if you use a regulator to drop the illumination, less current flows across the filament, it heats less, so glows less!!
So its now consuming lower watts!!
Similarly a fan at a lower speed will consume lower power!!
At full speed, it will consume the full rating, whatever it was meant to!!
