raksrules
Northstar
I have to do some work from home and for that i need to do the following
1. I am using Check Point secureclient VPN to connect to the VPN network
2. Connect to the terminal server using remote desktop, say the server name is
'abcd123'
But the first step is happening fine and i verified by opening the Intranet page of the client after loggin in the VPN, but i am not able to connect to terminal server at all.
I tried the following on command prompt also
ping abcd1234
And this ping worked fine.
So where does the issue lie ??
Please help as i will loose time but not getting this client connectivity happening.
I even tried that in the remote desktop window instead of 'abcd1234' i put its ip address (that i got from ping) but that too did not work.
'abcd123'
ping abcd1234
