replacement/custom ear-tips/buds for Sennheiser IE80?help!
siddharth
Contributor
i got the Sennheiser ie80 a few weeks back but i'm not getting the seal required for optimum performance despite a bunch of them provided in the package , the large double staged eartips come close but are far from perfection.
should i get customs or any thing else please help!!
Try Sony hybrid tips. I sugguest you borrow them and see if it helps with the fit. Hifiman bi-flange tips are also pretty good.
didn't knew m3 came with sony hybrids. got the perfect fit with the hybrids of my m3
if large tips fitting you than comply foam surely will help you.
regarding sony hybrid, these comes with mix size so only one or two may fit you and other will be wasted
i am also looking for small/ extra small size sony hybrid, so if you are not into small tips than i can take those and split the
expenses.
expenses.
sure
