So I bought a cheap H115i from a friend who said it was not cooling his 3900X well.
I tried it for myself, the pump works fine and RPM is being reported, I am using it with Noctuas so that's not an issue either.
I think the issue is with clogging due to growth or oxidation inside the pump/radiator, so I would like to take it apart.
The issue is, what coolant should I use in it afterwards?
Distilled water won't work because AIOs use mixed metals (Copper CPU block and Aluminium Radiator).
Where can I find anti-oxidation and anti-microbial drops for water? I really don't want to spend 1.5K on corsair coolant.
