Marcus Fenix
My bad. I didn't notice that in your first post. If your CPU is not a 3900X or some other high core count CPU which you stress a lot I think you are better off with an air cooler at this point.Yes but the purchase cost of that non-functional AIO plus this fluid costs more than a functional AIO so was looking to avoid it
Even then not sure if that fluid would be good for mixed metals in the long run
Here
Edit: the description says only use with nickel, brass and copper. So not useful for aluminum radiator + copper block.
Lets say your DIY repair works for sometime and then one fine day it wipes out your PC with a leak. Do you really feel that the risk is worth the benefit of having an AIO and that too a dying one?
