^^ Capabilities wise, they are both very similar. The main difference is the screen size and the stylus.
LOL,,, ok
Note 2 has 2gb RAM, trust me more RAM makes a world of difference in everyday usage. I dont understand these manufacturers, why do they skimp on RAM when its so cheap, and it makes a huge performance difference.
Hmm.. Yes indeed it does make a difference.. I to dont understand, RAMS for phones are cheap and still they dont use it.. One thing i found was that the phone gets more hot when More Ram is used.. THe chip's temp rises drastically....
I have both . Depends on where you want to use and what you want to use it for . If you travel less and are at one place in the day I say note . If you travel frequently then the s3 as not very comfortable to use when outside owing to its size . I use the note at home and s3 at work .
Hmm, Yes Ankush.. The size make a difference.. Unfortunately i am not as rich as u r so cant afford 2 phones of this price
U can help me out here tell me is there anything that one of these 2 phones cant do when Compared ???? Which is more Fluid ???
- - - Updated - - -
@op - n8 user here. sorry to interfere. may i know what issue you face with n8 ?. is it worth extending its warranty ?
Hey fellow N8 user..
Well my device is like now 2 years old ,i had extended its warranty
This phone of mine after the Anna Update started hanging ALOT, used to Restart again and again, i tried a number of things to improve it , but ALAS!!! didnt work ...
Then came Belle it was a lil better than the ANNA but still used to hang and Restart. or suddenly Choke on Processes..
I HAD LIKE
5000+ Messages saved send and Inbox Combined. I know it is a big load on this phone.. But still..
this present day it has Belle Refresh OS on it.. it is quite better from the OLD Belle but still occasionally hangs.. I Deleted almost 4000 messages from my phone, and now it seems to be fine .
But still SMS should not be a problem.
What all Problems r u facing ???
And Yes extending the Warranty is not bad, i got it done....
