Sapphire 6800 Series DX11 Graphics Card & Xigmatek Power Supplies
mediahome.in
New Member
Feedback: 186 / 2 / 0
Sapphire Radeon HD6850 1GB PCI-E 2.1 Graphics Card
The SAPPHIRE HD 6850 has a new architecture with a total of 960 stream processors and 48 texture units delivering massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 775MHz, together with a dedicated high speed interface to 1GB of GDDR5 memory running at 1000MHz (4.0 Gb/s effective) delivers class leading performance. It boasts a very modest active power consumption and, using Dynamic Power Management, the card has a super low-power idle mode.
Specification :
Brand|SAPPHIRE
Model|100315L
Interface|PCI Express 2.1 x16
Chipset Manufacturer|ATI
GPU|Radeon HD 6850
Core Clock|775MHz
Effective Memory Clock|1000MHz (4.0Gbps)
Memory Size|1GB
Memory Interface|256-bit
Memory Type|GDDR5
DirectX|DirectX 11
HDMI|1 x HDMI
DisplayPort|1 x DisplayPort
DVI|2 x DVI
RAMDAC|400 MHz
Max Resolution|2560 x 1600
CrossFireX Support|Yes
Cooler|With Fan
Dual-Link DVI Supported|Yes
HDCP Ready|Yes
Features|ATI Eyefinity Technology
|AMD HD3D Technology
|AMD Advanced Parallel Processing Technology
|3rd Generation TeraScale Engine
|HDMI 1.4a support with Deep Color, 7.1 High Bitrate Audio and 3D Stereoscopic support
|On chip HDCP Support
|ATI CrossFireX multi-GPU support for highly scalable performance. (Use up to four discrete cards with an AMD 790FX based motherboard)
|Enhanced Unified Video Decoder(UVD 3)
|Dynamic power management with ATI PowerPlay technology including memory clocks
|Dolby TrueHD and DTSHD Master Audio TM Support
|Enhanced Internet Brower Applications
Manufacturer Warranty|3 Years limited
Cost - Rs. 11300 + Shipping
Available in Limited Quantity
Sapphire Radeon HD6870 1GB PCI-E 2.1 Graphics Card
The SAPPHIRE HD 6870 has a new architecture with a total of 1120 stream processors and 56 texture units delivering massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 900MHz, together with a dedicated high speed interface to 1GB of GDDR5 memory running at 1050MHz (4.2 Gb/s effective) delivers class leading performance. It boasts a very modest active power consumption and, using Dynamic Power Management, the card has a super low-power idle mode.
Specification :
Brand|SAPPHIRE
Model|100314SR
GPU|Radeon HD 6870
Core Clock|900MHz
Effective Memory Clock|1050MHz (4.2Gbps)
Memory Size|1GB
Memory Type|GDDR5
DirectX|DirectX 11
HDMI|1 x HDMI
DisplayPort|2 x Mini DisplayPort
DVI|2 x DVI
RAMDAC|400 MHz
Cooler|With Fan
HDCP Ready|Yes
|AMD HD3D Technology
Cost - Rs. 15000 + Shipping
Xigmatek NRP-MC802 800W Modular Power Supply
Xigmatek new MC series upgrades with 12V solid state capacitors, 12V single rail and DC to DC circuit design. New MC series provides more powerful, more efficient, and more stable output for extreme gaming users. Keeps “GO GREEN” environment-protecting concept with recycled material package and 80Plus Bronze certification.
Specification :
Brand|XIGMATEK
Model|NRP-MC802
Type|ATX12V v2.3
Maximum Power|800W
Fans|1 x 14cm fan, Max. 1800RPM±10%
PFC|Active
Main Connector|20+4Pin
+12V Rails|Single
PCI-Express Connector|2 x 6+2-Pin, 2 x 6-Pin
SATA Power Connector|10
SLI|Ready
CrossFire|Ready
Hold-up Time|16ms min.
Modular|Yes
Efficiency|>88%
Energy-Efficient|80 PLUS BRONZE Certified
Over Voltage Protection|Yes
Input Voltage|100 - 240 V
Input Frequency Range|47 - 63 Hz
Input Current|9A @ 115V, 5A @ 230V
Output|+3.3V@30A, +5V@30A, +12V@64A, -12V@0.6A, +5VSB@3.0A
MTBF|>100,000 Hours
Dimensions|150mm(L) x 180mm(W) x 86mm(H)
Features|Over 88% efficiency at 230V and 80Plus Bronze certified at 115V for higher efficiency, lower energy loss, cooler our Earth.
|12V rail solid state capacitors and Japanese main capacitor for longer life and more stable output.
|Single 12V output rail for the best extreme gamer's PC compatibility.
|Label wattage is real continuously wattage, not peak output at 100% loading.
|0.99 Active PFC rate for the highest AC utility rate and active switch for universal AC voltage.
|Low ripple noise DC output for better devices performance.
|Low noise level by 14cm cooling fan and thermal fan control to keep low RPM in typical loading.
|Two PCIe 6pin and two PCIe 6+2(8)pin connectors for multiple high-end graphic cards.
|All DC cables with mesh sleeve to reduce airflow resistance for better thermal release in PC case.
|Two 12V CPU 8pin connectors for double CPU server and workstation motherboard.
Cost - Rs. 7000 + Shipping
Xigmatek NRP-MC1002 1000W Modular Power Supply
Specification :
Brand|XIGMATEK
Model|NRP-MC1002
Type|ATX12V v2.3
Maximum Power|1000W
PFC|Active
+12V Rails|Single
PCI-Express Connector|3 x 6+2-Pin, 3 x 6-Pin
SLI|Ready
CrossFire|Ready
Modular|Yes
Efficiency|>88%
Input Current|15A @ 115V, 10A @ 230V
Output|+3.3V@30A, +5V@30A, +12V@80A, -12V@0.8A, +5VSB@4.0A
MTBF|>100,000 Hours
|Three PCIe 6pin and three PCIe 6+2(8)pin connectors for multiple high-end graphic cards.
Cost - Rs. 9000 + Shipping
Combo Deals :
HD6850 + MC802 - Rs. 17800 + Rs. 400 Shipping
HD6850 + MC1002 - Rs. 19800 + Rs. 400 Shipping
HD6870 + MC802 - Rs. 21500 + Rs. 400 Shipping
HD6870 + MC1002 - Rs. 23500 + Rs. 400 Shipping
To Order Combo :
Order the Graphics Card alone and mention your TE ID & the combo details in the comments and send money accordingly.
To Order Separately Visit :
Sapphire Radeon HD6850 1GB PCI-E 2.0 Graphics Card
Sapphire Radeon HD6870 1GB PCI-E 2.0 Graphics Card
Mechanic
Feedback: 0 / 0 / 0
i expected the HD6850 to be cheaper :(
its 179$ in international market
didn't expect it to go above 10k
ka0s
Feedback: 1 / 0 / 0
Prices will definately go down 100%...
6870 should cost arnd 11-12k just wait for diwali :D
rite
Feedback: 2 / 0 / 0
IMO the prices of 6850 will stay north of 8-9k for the next 6-12 months.
They might go down by about 500-1500 bucks over the next 3-12 months, but that is about it imo.
