Graphic Cards Sapphire Rx 570 GPU Fans suddenly stopped spinning and LED logo lights stopped working too.
BlueFros7
Recruit
So today all of a sudden my GPU's logo lights suddenly stopped glowing and the fans stopped spinning. There are two fans and when i turn on the system one of them rotates for like a millisecond or two and then stops. Previously the GPU fan's would start spinning whenever temps were above 50 c but now even when temps hit 86 c the fans still don't run
To make sure that it's not just idling i ran furmark and GTA V at ultra settings and even then the fans still didn't turn on. I even tried a custom fan curve in MSI Afterburner and nothing happened.
Searching up on YouTube, i saw that you had to disable Zero RPM in AMD Adrenaline and that didn't work either.
PSU is Seasonic S12II 620w, GPU is Sapphire Rx 570 Nitro Plus Edition
any idea what could be the problem, don't know what other information i should provide.
awestorr
if both the led and fans arent working, maybe check the connector in the pcb.
because looks like the gpu is good but something is definitely upbwith fans and leds.
BlueFros7
Recruit
will that require any expertise?
i can screw and unscrew stuff and maybe watch from youtube and do something, not more than that.
don't wanna break this tbf
awestorr
just the basic knowledge on how to remove connectors and screws.
maybe dont do it if u have never opened a gpu before and dont wanma risk it.
Looks like a issue with your power supply to LED & Fans is not working, is it in warranty?
Disassembling GPU is not rocket science but still you can try this OR this , just remember by this time your thermal paste must have dried up so make sure you have it ready before you decide to open it. If you don't have a good one's in near by stores , you can get a basic one for time being from nearby store. Don't open your GPU w/out thermal paste ready because after troubleshooting still the fans don't work your gfx card will be very hot plate which can damage the card very fast.
