I really hope you know what you're doing personally know a guy who fried his entire system just by using a different generation of cables from same brand.Hi I would like to buy SATA power cables for any PSU. I will re-pin them to match mine.
would have sent you my extra cables , that is if i wasnt a data hoarder just like you and wasnt already asking friends for their extra cables, i do plan to order some sata splitter soon i can order extra if youd like though i order in bulk, saves on shipping , as shipping costs more than the product itselfYes I am taking care of this. I have in fact gotten my first self rewired cable tested by an electrician for compatibility against the original cable for the psu. I tested & compared it myself using a continuity meter too.
Thanks for the bump![]()
I am experimenting with zfs. What do you use?would have sent you my extra cables , that is if i wasnt a data hoarder just like you and wasnt already asking friends for their extra cables, i do plan to order some sata splitter soon i can order extra if youd like though i order in bulk, saves on shipping , as shipping costs more than the product itself![]()
From where do you order?would have sent you my extra cables , that is if i wasnt a data hoarder just like you and wasnt already asking friends for their extra cables, i do plan to order some sata splitter soon i can order extra if youd like though i order in bulk, saves on shipping , as shipping costs more than the product itself![]()
Not really sure, its original Corsair HX750 cables (the PSU was RMA'd and they never took the cables) So may be 750rs ?I have never bought just the cables so I have no idea. How much do you want for them?l
For ZFS i will ping you in DMs but i mostly use Z2 as it gives sufficient redundancy without having too much over head and easier to manage as well.I am experimenting with zfs. What do you use?
It's surprising that these parts aren't available in India even at a unreasonable price. Cooler Master asked me to import it from Europe that too from RMA products.
yes when you pass through the HBA to truenas and it is configured to IT mode not RAID mode you can manage the drive spin up , if they are connected to sata ports on motherboard then it would depend upon the motherboard controller and should have some control in the motherboard bios , most serve bios does have some options regarding this.How do we configure this in TrueNas? Also won't this need hardware support from the motherboard? Isn't there a pin which controls this? Pin 11 I think?
I am not in a hba yet. What's your overall configuration?yes when you pass through the HBA to truenas and it is configured to IT mode not RAID mode you can manage the drive spin up , if they are connected to sata ports on motherboard then it would depend upon the motherboard controller and should have some control in the motherboard bios , most serve bios does have some options regarding this.
