If you are unable to find one in desired length, you could try making one yourself.
Just search for a c13/c14 socket (make sure to check if you need a male or female socket), posting an example
Amazon.in: Buy A3sprime™ AC 250V 10A Female 3Pin IEC320 C13 Power Adapter Plug Power Socket Connector (3 Pin Female) online at low price in India on Amazon.in. Check out A3sprime™ AC 250V 10A Female 3Pin IEC320 C13 Power Adapter Plug Power Socket Connector (3 Pin Female) reviews, ratings...
www.amazon.in
Get a nice cable with L/N/E 3 core in your desired length and a plug.
Should work as good as a ready made cable, but overall cost could be more
