Hi,
I'm planning to create a steam machine using the SteamOS and creating a console like system that would be connected to my TV.
I have an MSI Radeon RX 6400 Aero ITX which I'm planning to use in it.
Any custom proprietary standards would also work provided it comes with the motherboard to go with it.
Dimension limitation on the face side would be 2ft x 0.5ft, but would prefer them to be as small as possible (no limitations on the depth)
Price limits:
- 10k for just the cabinet if it supports ITX form factor motherboards or any other standard motherboards.
- 25k for barebones kit with non proprietary standards but should come with a motherboard (can increase if CPU is also included)
Haven't decided on CPU yet so willing to accept both AMD and Intel provided they perform good enough for 1080p medium gaming without throttling too much in a restrictive form factor.
Thanks.
Price limits:
Thanks.
