Sony Vegas Pro 9.0a
sickizblank
Contributor
Okay I'm facing a problem.
I'm on Vista x64 SP2.
Got KLite 5.0 Codec Pack installed.
Earlier I had Vegas Platinum 9.0a but I planned to upgrade it to Vegas Pro 9.0a.
Thing happening is , earlier all the .avi files used to get detected properly in Vegas.
Now since I have upgraded to Vegas Pro 9.0a all the .avi files are just getting detected as Audio files. I have no clue why this is happening.
I have codec all the required codecs I suppose because earlier when I was on the platinum version everything was working perfectly fine.
I'm not very good at codecs so you guys need to help me from scratch!
The .avi files basically include all the Movies and such , aXXo rips for example do not work. (Which used to work in the earlier Platinum version)
I tried uninstalling my codec pack and reinstalling it again. That didn't work either.
Please find me a solution to this. :(
Thanks
