This is my first review on TechEnclave and the reason that i felt that i need to do a review is cause i have been using reviews to buy stuff for a long time and so I Thought why not give something back.
So here we go - I Got these buds a couple of months back - ordered them from Ebay and they came in a nice Black Box. Apart from the earbuds the box had a nice Black Leather Pouch for carrying the earphones and i simply love it, no more entangled wires now !! Also you get 3 pairs of silicone buds and the medium size is factory fitted on the earphones - if you want you can go for a bigger bud - if the medium one is loose for you or a smaller one if the medium one is too big to fit in your ear canal.
The earphone has got a 3.5 mm jack and a nice wire that is long enough to wear the earphones and put the phone connected to them in your hip or front jeans pocket. These work pretty well with an I-phone or the Samsung Android Phones or the Nokia ones that have a 3.5mm jack.
The sound is absolutely crisp, clear and pretty loud. The Bass is sufficient. These earphones are better than those that come with an I-Pod or any of the Cell Phones.
Listening to tracks is a pleasure on these - you can easily hear each and every instrument in the background. Mind you the volume can really be loud and at no point does the Bass overwhelm the Midrange or the Treble.
Also for people planning to use them with the phone there is a version of the same buds that comes with a built in microphone that costs 250 bucks more and would be a good buy - its MP-21
