CPU/Mobo Sound problem....
baptupaul
Apprentice
Hello frnds i have facing some problem since some days.. now i should explain it.. when ever i m playing any music or video in player(windows media player or VLC player) my sounds volume going down gradually and it become mute..if i try to increase the volume level its not increasing.... but if i stop playing music or video..and after some time if i try to increase the volume level that time in works but if i play again any music or vedio..the same problem arrise again...
My english is not so good..i m sorry for that.. i will be oblized if u give ur valuable suggestion over this problem..
My pc configaration:-
Processor :AMD Athlon II*4635 processor 2.90 GHz
Motherboard :Assus m4n68tm
OS :windows 7 64 bit
Did you install the latest driver of your motherboard, mainly audio and chip-set.
Did you check you speaker with any computer of equipment, does it work fine.
