Speed Problems
Rajat Kokane
Inactive
Beginner
i have a problem with my internet connection. I paid for a 2 mbps plan (not much i know). the upload speed is fine but the download speed is just 1 mbps on my pc. Whenever i do a Speedtest on my phone, it comes out as 2mbps but its much low on my PC. Is something wrong with my PC or its the ISP's fault?
Sorry for my bad english :v
1- test speed on fast.com
2- what software are you using to measure speed in PC? Try downloading 10-20MB file directly from a website. Example, download an installer for MPC-HC from its home page or load an album in Imgur.com. What speed are you getting there?
3- if you still find speed to be slow, call your ISP and ask them to troubleshoot it.
I did the test on Ookla speedtest, it shows about 1.5 mbps on PC and 2 mbps on my phone
On fast.com, it shows 1.2mbps
tried downloading a 1 gb file, and the download speed doesnt exceed 130 kBps on PC, its even less on my phone although it shows 2mbps speed on the speedtest app...
i think something is wrong with my ISP...
1.2mbps its not .8 mbps i pay for 20mbps and get between 1.5-1.8
its normal i guess
