Guide Speed Tweaks For Firefox 1.0 Final and Earlier.
  • Thread starter Thread starter MysticYogi
  • Start date Start date
After experimenting with various builds of Firefox, I've figured out how to get it to run just as fast as IE! These settings may put additional load on web sites though.
Type in the Address Bar; about:config
Then scroll over to the following settings and adjust:
network.http.max-connections : 40
network.http.max-connections-per-server : 20
network.http.max-persistent-connections-per-server : 20
network.http.pipelining : True
network.http.pipelining.maxrequests : 32
network.http.proxy.pipelining : True
lose and relaunch browser and watch it fly!
If you'nt sure wht ur doing. You can do the same with the extension that FireFox provides.
Check : https://update.mozilla.org/extensions/
