strange problem with FIFA 2006 !
digital_brain
Discoverer
I am having this strange problem with fifa 06 ...while the game runs....in the main menu....the options automatically changes.. i.e say .at first when the language option comes..the languge options changes automatically and continuously....even if i dont click anything !!!! :@ !.Do you guys have any idea why its happening so... :huh: please help !!! :huh:
One of my friends also has the same problem.He is really frustrated. The same copy of the game works perfectly on my PC but changes languages on his PC.
uninstall and put something better, arent you tired of playing the same shit released every year with a change in the date?
But what if he hasn't played 2005 and 2004? Makes sense if the person got the latest soccer game with -
1. Better graphics
2. Better Roster
3. Better commentary
4. Added motion captures and face detail
5. Added online features
6. Slightly better control
Doesn't it?
it is the same as 2003 and if he hasnt played that, its the same as 2002.
i played 97 and 99 and realized that being a sucker for the third or tenth time is just a mindless waste of blanks.
LOL, true, get PES 5,much much better than FIFA in terms of gameplay and grafix too (I wonder about ppl who say FIFA has better grafix).
As for rosters there are zillions of patches available on the net to get the latest rosters (with the latest transfers).
Commentary: Mute the PES 5 commentary and put on some cool track, Peter Brackley and Trevor Brooking suck..
Control: Football games arent meant to be played with keyboard so geta a good controller (Though I play the game with Keyboard :D).
In fact FIFA keeps degrading every year , I liked FIFA 99 and FIFA 2003 (Somewhat better) but its the same $hit every year with fancy terms like "First touch" being fed to the people every year.
DC.
Wait ! I'll tell you how to solve the problem. This is when you have a USB keyboard or gamepad.
Just download and apply the patch from here, it'll work perfectly :D !
but disabling the hid thing doesnt that disable the mouse.
i am having the same prob at skirmish. & also i tried 1.1 patch of fifa still the problem persists.
also anish is that link for version 1.1 patch?
Nope ...its not game pad problem... actually many people having the same problem....
I found this tutorial .. which solved my problem... infact its pretty usefull !!!
Gamepad Configuration
a tutorial by Rinaldo Zocca
This tutorial explains how to configure your gamepad modifying the file devdata.dat.
Step 1: Know the name of your gamepad
First thing to do is to see the name of your gamepad, go in the control panel and search the name of your gamepad: in the example I have “Logitech DualAction USBâ€
Step 2: open the devdata.dat
Now you should find the devdata.dat. Go in the folder FIFA 06\user under your Documents folder. It should be there. If you have not a devdata.dat then it will be used the devdata.dat in the folder \EA SPORTS\FIFA 06\data\input uder your Programs folder. Open the file with notepad.
Step 3: find your gamepad or add it
All the names of the gamepads recognized by FIFA are listed between two square brackets, eventually separated by vertical bars. Search your gamepad. Pay attention that the name must be exactly the same that you have seen in the control panel, for example if you find
[Logitech Dual Action|Logitech Dual Action (USB)|Logitech Dual Action USB]
It is not the same as “Logitech DualAction USB†because ther is a space between Dual Action (this is what happened to me!)
If you don’t find the name of your gamepad don’t worry. Simply add a line inserting the name of your gamepad like this
[Name of my gamepad]
Step 4: uderstanding and modifying the data structure
Now you can see same data below the name of a gamepad. I have coulored them in order to recognize them better:
DEADZONES=0.3,0.3,0.3
2|24|3,2|25|4,5|26|5,5|27|6,1|22|5,1|23|6,0|20|3,0|21|4,0|18|21,0|19|22,0|16|19,0|17|20,0|2|2,1|0|2,2|3|2,3|1|2,4|10|2,5|13|2,6|11|2,7|14|2,9|8|2,8|9|2,10|12|2,11|15|2
2|24|3,2|25|4,5|26|5,5|27|6,1|22|5,1|23|6,0|20|3,0|21|4,0|18|21,0|19|22,0|16|19,0|17|20,0|3|2,1|2|2,2|1|2,3|0|2,4|10|2,5|13|2,6|11|2,7|14|2,9|8|2,8|9|2,10|12|2,11|15|2
The line
defines the sensibility of the gamepad and usually you can keep the default values without problems.
The blue stream is used for navigating the menu. The green stream is used for playing. The Red one I don’t know. There is not any reason to have them different, so you can replicate the same stream three times
Now let’s go to see the stream structure, they are triplets of numbers separated by commas. The numbers themselves are separated by vertical bars. The 2nd and 3rd number of each triplet identify a special function in the game as described in the following table.
Standard key Function 2nd and 3rd number
W Through Ball \GK Charge 0|2
D Shoot\Conservative tackle 1|2
S Pass\Switch Player 2|2
A Cross\Long pass\Sliding tackle 3|2
Escape Escape 8|2
5 numericpad Change mentality 9|2
Q Trigger run 10|2
Z Cancel\Dummy move 11|2
Unknown 12|2
E Sprint 13|2
C Pace control\Walk defense 14|2
Shift First touch 15|2
Arrows
Left joystick Movements 20|3
21|4
22|5
23|6
Shift Arrows
Right joystick First touch\free style movements 24|3
25|4
26|5
27|6
Numeric Pad
Digital pad Tactic selector 16|19
1720
18|21
19|22
The first number of each triplet is the “identifier†of a control on your gamepad. Changing the first number of a triplet you change the control assigned to a specific function.
Unfotunately the control “identifier†is not a standard and so the only way to proceed to try.
Let’s see an example
2|24|3, Assigns axes 2 and 5 to “first touch movementsâ€
2|25|4,
5|26|5,
5|27|6,
1|22|5, Assigns axes 0 and 1 to “movementsâ€
1|23|6,
0|20|3,
0|21|4,
0|18|21, Assigns pad 0 “Tactic selectorâ€
0|19|22,
0|16|19,
0|17|20,
0|2|2, Assign key 0 to Pass\Switch Player
1|0|2, Assign key 1 to Through Ball \GK Charge
2|3|2, Assign key 2 to Cross\Long pass\Sliding tackle
3|1|2, Assign key 3 to Shoot\Conservative tackle
4|10|2, Assign key 4 to Trigger run
5|13|2, Assign key 5 to Sprint
6|11|2, Assign key 6 to Cancel\Dummy move
7|14|2, Assign key 7 to Pace control\Walk defense
9|8|2, Assign key 9 to Escape
8|9|2, Assign key 8 to Change mentality
10|12|2, Assign key 10 to Unknown
11|15|2 Assign key 11 to First touch
Now you can start to modify the data according to your preferences. When you start the game you will have your gamepad enabled and with the default setting that you have choosen.
Good luck!
