Graphic Cards Strange Problem
blaster
I recently purchased a intel original 915 Mobo , 3.0 Mhz processor , 512 DDR Ram , UPS , and combo Drive
Now i have a very Strange problem
My PC restartd abruptly when ever i start Sound recorder and Condition Zero.
But games like NFS Underground , Splinter Cell works fine.
I havnt run memtest till now , and temp is around 55-66 Degrees
Can any one tell whats wrong ???
I run windows XP Sp2
:huh: :huh: :huh: :huh:
CS is Counter Strike
And regarding problem ,
The PC was for my frnd.
He is using onboard sound card only.
The prob occours some times with winamp (rarely)
And am usin CZ 1.6 only
Do check if DirectX is installed properly.
Sometimes, due to a bad or corrupt installation of DirectX also, a game crashes at loading to cause the comp to restart.
OK will surely check ,
actually some techies had suggested to check sound drivers , but due to timing of backup , those posts are gone , wld try all suggestions and will tell u result
