S sarkararko Inactive Contributor Aug 29, 2008 #1 whenever i reset my pc or there is a power cut or improper shutdown and then when i turn on the pc the windows never scan my hard disk ????:no: :huh: :ashamed:
S sarkararko Inactive Contributor Aug 29, 2008 #3 rASCAL said: thats probably because ur hdd format is NTFS Click to expand... all right nothing can be done ?????
WingZero Forerunner Aug 30, 2008 #4 ^^check manually thru windows...rightclick on the drive u wanna check..eg C: then click properties..tools..n check now..
V vivek009 Inactive Apprentice Aug 30, 2008 #5 Thats the same problem i was facing and now i m satisfied that it is due to NTFS. Thanks a lot people.
