My su-kam inverter has two charging modes, normal & high current , recently a su-kam engineer had come to fix some issue with the inverter , he switched the charging mode to high current after seeing that i had a tubular battery .
He said for tubular batteries inverter should be in high current charging mode .
But the inverter manual says that high current charging is to used when fast recharging of battery is needed due to frequent power cuts .
Is it safe to keep the inverter in high current mode ?
