Please suggest 120mm Blue LED fan for my HAF 922
Chirag, do you know where I can get sickle flow? Local dealer here in Bangalore claimed there is no such thing. I ended up buying Scythe Kama Flow 2 from Prime, which might be somewhat better but more expensive too.
This is confusing. Following the part number from COOLER MASTER R4-L2R-20CR-GP 120mm Red LED Case Fan - TheITWares, R4-L2R-20CR-GP, it leads to the silent fan. I heard silent fan doesn't move any air, so is truly silent .
The legendary sickle flows are R4-C2R-20AC-GP as reviewed here 120 mm Fan Roundup, Part 2: 1350 RPM or Higher Rotation Speed. Page 4 - X-bit labs. Are they same as silent fans?
I didn't know xtra flow is the successor of sickle flow, thanks.
I confirmed with hardwire.in, and they say their fan is r4-l2r-20cg-gp. This is also the silent fan. If CoolerMaster has discontinued sickle flows (doesn't appear on their website any more), only old stock can help us. Or we can wait for good reviews of the Xtra-Flow fans and see if it lives up to the reputation of sickle flows.^^ Point 1) is perfectly valid, I think the 2) point is contentious because it can be an error on part of proprietor of The IT Wares (OR whoever maintains the website). So best is go on hardwire.in and get the Cooler Master RED / Green LED fans (with smoked plastic body and not the transparent body). Technically the Xtra-Flow displaces the Cooler Master Blade Master (non-LED fan) but because of its pricing trends it is often too expensive OR at times cannibalizing the sales of Sickle Flow and the Blade Master.
