Suggest led tv in 40k
indresh88
Hi, I just made up my mind to purchase a brand new led tv. I have visited many retailer here in my city,but not received guidance, so asking help here..
I see 4 models of 32 inch that suites best for me
1. lg le5500
2. lg lv3730
3.sony ex520
4.samsung d5000
Now tell me which led should be best cost effective.
You can suggest me any other brands if it fits the following criteria,
budget 40k-45k
size 32 inch
resolution full hd
features : hdmi ports, usb ports, good support of usb movie format, good audio output, bluetooth
Thanks..
I have the 40D5000, its really good.
Plus the format support is wide, can even read NTFS hard disks...
You can go for the 32 inch version, it must be having the same features.. :)
sasmung 32D5900 should be a good choice its from smart tv table so its has more online features but i hear apps for india are quite less.
Sony ex520 couldnt read xvid/divx
wanted Samsung 32D5900 but was not available yet in Mumbai.
Bought LG 32LV3730, it could read all types of media
In Delhi, Samsug grey market import 40" smart TV costs Rs 42K. Their buying price from importers is Rs 40.5K.
Bought two and they work perfectly fine.
indresh88 said:
is it support subtitles?
yes it does .
Its unfortunate that none of the south grey dealers have samsung.
The D5000 street prices are about the same,i believe Lord Nemisis bought one in showroom for similar price.
The 32CX520 should cost around 24k to 27k.
indresh88 said:
samsung 32d5900 available in india?
and tell me that if sony cx520 support .mkv?
Yes its available in india check samsung india website.
CX520 and above models doesn't support MKV nor does it support NTFS formated HDD.
