Budget 10-15K Suggest Long Battery + Auto Call Recording (10 -15K)
Emperor
Hi,
primary use calling .. long long battery life for constant Calling (out going + incoming call).
Auto call recording facility shoulbd be there and caller from other end shouldn't get notice sound that his/her call get Recorded.
Any other good features are added advantage.
Thanks
I bought Poco M2 Pro from flipkart on 24 jan 2021, it has 5000 mah battery and i can tell u it never disappointed me in battery life. It has many other awesome features too, u can give it a search, its my suggestion for ur question.
I like my Samsung M21 which lasts 3 days with my moderate usage... this model just launched or launching soon at MRP 12.5k with mostly same specs and camera module bumped up to gen2.
is samsung M series have some SERIOUS issue? (like Network/Call Quality)... as I read with few forums etc.
Exisitng Redmi Note 5 pro (2017 bought) 4000Mhz not sustaining till end of the day
You could also buy a simple/non-smart phone just for calling. They should definitely fair better in battery department.
actually hunting handset for my Elder brother, his RN5 Pro died after 3 yrs (battery issue).
He have medium size palm and Moto G40 is good device but size/weight will be BULKY for him, considering he is coming from Redmi Note 5 Pro
I also suggest him same thing, get battery replaced for RN 5 pro and buy non-smart phone just for calling...
Thanks for suggestion
You can just get the battery replaced from mi service center... Shouldn't cost more than 1k
Sorry just read that you've already suggested this to your brother
Battery replaced from local shop, as 2 month before here at my place was under Lock down.
Now, the same replaced battery TOO swollen .... and local shop promise to get it replaced in 3 days ..
Shop Technician also told that it's due to over charging... but it never kept in charging more then 80%, so no question arises of over charging.
... i think Redmi Note 5 Pro life is over (this is just 3.5 yrs old)
I think. Just take refund money from shopkeeper and get original replacement from mi service center. Had replaced my battery once, it worked like new for me at least
ok... but as battery is used since last 2 month and now he is ready to get it replace with new battery.. so ...
but if I again get same issue soon, then deffinesly will go with Authorized Service Center.
I don't know any APP that can record call without ANY INTIMATION to person at other end, if you have any suggestion for such app let me know.
Lots of apps i think can do with root or custom roms not many without .
My cousin actually has same requirement as you as shes using one plus 5 and it had inbuilt auto call recording by default but newer one plusses after 7t dont have , but she cant root etc so i came to this thread looking for suggestions too actually.
Hi, I too not in rooting, nor have tech knolwedge for rooting etc. thus was looking phone that by default support Auto Call Recording
