LG Ultragear QHD (32 inch / 80 cm) 165 Hz 1ms, Nvidia G-Sync Compatible, FreeSync Premium, HDR 10, HDMI, Tilt, Height, Pivot Stand, VA Panel Gaming Monitor (32GN650) https://amzn.eu/d/1SjLBsrHi.... I am looking to buy a 32 Inch Monitor for Gaming & 3D Drawing related purposes..2k Mainly , 4k if affordable in my budget...No Curved Display
Kindly suggest me some Monitors for Budget 30k-35k...
Difference is in the seller. The 32GK650 sold for 20-21k last year. HDR10 is pointless in cheap monitors because the peak brightness is too less and it results in a worse experience with HDR switched on. Also, the GN650 is 95% sRGB compared to 99% sRGB for GK650.LG Ultragear QHD (32 inch / 80 cm) 165 Hz 1ms, Nvidia G-Sync Compatible, FreeSync Premium, HDR 10, HDMI, Tilt, Height, Pivot Stand, VA Panel Gaming Monitor (32GN650) https://amzn.eu/d/1SjLBsr
While mine is the below one
LG Ultragear 80 cm (32 inches) QHD (2K) Gaming Monitor with 144Hz,1ms, Radeon Freesync, Display Port, HDMI x 2-32GK650 https://amzn.eu/d/9aX4NFv
Both are VA panels but I am not able to understand my monitor is costly than the one I suggested because it's having HDR 10 which my monitor does not have.
So decide for yourself which is best. Okay.
I have a 6800xt gaming z trio .. i want mainly for drawing needs .. so higher refresh rate is not must .. i want something balancedWhich GPU do you have? Do you need a high refresh rate display or you're satisfied with 60 FPS?
If you don't need high refresh rate, I'd recommend going for 4k instead of qHD, it will give much sharper image for your drawing needs.
If you do want high refresh rate, make sure your GPU has enough power to drive qHD at 100+ FPS.
Get a 4K60 IPS monitor instead as you will appreciate the larger real estate at higher resolutions when working between applications or even on a larger canvas.I have a 6800xt gaming z trio .. i want mainly for drawing needs .. so higher refresh rate is not must .. i want something balanced
