Suggestions for Car Audio System Budget 20K
Hi guys
Wanted suggestions for Car Audio system.
Suggest Car Deck with following funtionality
FM - MP3 - Wma - CDR/RW - Auxillary input [so i can connect my mp3 player]
Brands - > Pioneer , Sony Xplod , Blaupunkt , JBL , Alpine [available]
Speakers
2 front and 2 rear
Brands - > JBL , Sound Storm , Pioneer , Sony , Blaupunkt [available]
Please suggest ne other bands too from above.
Guys u know i aint that gr8 with judging audio so wanted ur suggestions.
Budget is max 20K
Hey
Out of the player and speaker list u can cancel the sonyxplod dey suck big time ,i had a lot of problems.sony amps and woffersare gud thou
u will have to keep 5k aside for the amp otherwise u will not use the full power of the speakers u use so i wold say go for JBL speakers (the original one u get a 1 yr warrenty )cus the rule big time say anther 5k there so ur left with 10 for ur player go for Alpine or Blaupunkt and to my knowledge JBL does not make players correct me if i am wrong,pioneer arent bad either
Here's a pretty decent setup.
1. HU - Pioneer DEH-5750
2. Speakers (JBL components for the front, coaxials for the rear)
3. Amp - Pioneer 6100F (4 channel bridgeable) or JBL
4. Sub - JBL 10 or 12"
Regards.
YA FORGET SONY EXPLOD frm that list two MP3 car audios frm my cars had lens probs and lens was changed in both the head units. buy ne thing but sony MP3 player.
I had almost finalized on the pioneer deh-6850 but not sure if it supports FM and Aux input , will ask at the shop where i enquired about this systems.
Is amps compulsary , what if i add later.
EDIT Added Later
Guys did a bit of googling and found detailed info on the 6850
This is the list of features
Pioneer's DEH-P6850MP has all the capabilities any car audio enthusiast would require in a CD Tuner. Bringing the convenince of i-POD & Bluetooth adaptability, Rotary Commander with menu access and OEL Pure Blue Display, this unit will deliver on all your car audio expectations.
CD Features
S-10.3 Mechanism
Playback for AAC Files (Advanced Audio Coding as used by iTunes)
Playback for MP3, WMA and WAV Files
ID3 Tag Recognition
Disc Title Memory w/10 characters (48 discs)
BMX (BiMetric Equalizer)
Digital Compression Selection
CD-R and CD-RW Compatible
1-Bit D/A Converter, 8fs Digital Filter
CD Text Display with Scroll Function
File and Folder List Search
Track Scan
Track / Manual Search
Pause
Repeat
Random Play
Supertuner Features
Supertuner IIID with Digital Processing
Automatic Seek (Up / Down)
24-station 6 preset buttons
BSM (Best Stations Memory)
Selectable Level Local / DX
List Search
9kHz / 10kHz AM switching
18 FM and 6 AM presets
DAB (External Tuner) Control
Multiplay CD Control Features
CD Text Display with Title Scroll
ITS (Instant Track Selection)
Disc Title Memory
Track & Disc Scan
Disc List Search
Repeat Play (Track/Disc/Mag)
CD pause
Random Play (Disc / Magazine)
Digital Compression selection on MCD
Audio Features
MOSFET 50 Watts x 4 high power
EEQ (Easy Equalizer)
7-Band Graphic EQ within EQ
5 Preset + 2 Custom EQ Mode
Bass and Treble Tone Controls
Selectable 3-Mode Loudness Control
LPF Subwoofer Crossover (50, 80, 125Hz @ -12dB/oct.)
Normal/Reverse Subwoofer Phase Selection
Direct Sub Drive (from headunit power)
HPF (High Pass Filter 50, 80, 125Hz @ -12dB/oct.)
Electronic Volume / Balance / Fader controls
4 Volts RCA Preout Level
3 prs RCA Preout (Front + Rear + Sub/Non-Fading)
SLA (Source Level Adjuster)
Additional Features
10 Key IR Remote Control
Flap-Type DFS (Detachable Face Security)
DFS Hard Carry case included
Battery Voltage Meter
Operation Beep Tone
Detach Face Reminder Warning Beep
External Source TV, DVD, CD, CD Control
AUX Input via CD-RB10 or CD-RB20
iPOD Adapter Ready (CD-IB100 via EXT control)
OEL Pure Blue (Organic ElectroLuminescent) Display
Display Brightness Adjustment
Pure Blue button illumination
Level Indicators
Cellular Mute/Attenuate for In-car phone kit
Clock (without animation)
System / auto antenna relay control
Front or rear mounting options
Toyota/Nissan factory mounting holes
Source:- http://www.pioneer.com.au/car_entertainment/amplifiers/dehp6850mp/index.html#anch_1
This cost approx 9K actually 15K with bill.
getting this as my audio unit its fixed now.
Dats a very gud player my bro has it in his car n he connects his ipod n all to it n its got fm dont worry,9k is a very gud price cus he bought it for 12k without bill.
An amp is necessary specially if ur puttin JBL becoz the player does not have enough power to run 4 or even 2 speaker,ok for a short period of time.
if u play loud music den an amp is surelly necessary other wise the speakers will firstly JARRR,ad after a wile ur player ic will go once dat goes ur player is gone.
n forget about woffers,JBL have enough bass to keep u jumpin.(dat with an amp connected thou)
Happy listening
I have a pioneer deh-4850 (the predecessor) and Soundstream speakers, 2 components in front and 2 3- ways behind. they fckn sound awesome..
I'd recommend the speakers anytime.. I had a tough time chosing between them and JBL's. I'd suggest you go and hear those speakers out. Also go in for an amp if you can. will sound much better. As bennick says no need for a sub-woofer.
Cheers.
Amplifier is compulsory for High end Ovals itself.
You dont want you Deck to get screwed now do you?.
Get a 12" Pioneer 306DVC Woofer. One of the best woofers around, and awesome effect. I have to say. Great VFM too. I got it for ~Rs.5000, 3 - 4 months back.
I got myself a Sony Xplod, 440W Amp.( Only use the woofer on the Amp).
Its in my Innova, so i didnt have space for Ovals, but i replaced the 2 Front and 2 Rear door Speakers, with Round, 4-Way Speakers. Which are awesome as well.
deejay said:
Which car btw QuadMaster ??
The car is a Maruti Swift.
I saw a few amps do lemme know which are better.
Speakers will listen there personally and select.
But can you give me some good 2xfront and 2xrear speaker suggestions.
How much rms will be good enuf.
Will get JBL or Soundstorm speakers only.
No woofers.
JBL Amps
PX300.4
600-Watt 4-Channel Power Amplifier with electronic crossover
http://www.jbl.com/car/products/pro...P&ser=POS&language=ENG&country=IN&region=ASIA
Pioneer AMP
GM-6100F
http://www.pioneer.com.sg/storefront/ProductDetail/default.asp?ProductId=301&CatId=,2,26
Ne idea how much wud they cost.
to my knowledge JBL amps r very expensive,say in the range of 8k to 10k,pioneer are also gud but a bit cheaper ........if u want a cheap but very gud 1 u can go gor the sony 4way its around 5k,ive got dat 1 with JBL 350w(120rms not sure)mindblowing sound,,,,the swift has got the front speakers on the door rite,,,
Can some one suggest me amps for approx 5K nothing more than that.
Is pioneer 6100 better than the sony's amp.
will ask about the jbl amps also as i dont have the idea of the cost of it.
Guys waiitng for speaker recommendations.
It shall be 5.25 in the front and 6.25 in the rear.
or are ovals better at the rear.
please suggest me , am a bit confused.
this happens where there are so many options to choose from.
No woofers.
JBL Amps
PX300.4
Pioneer AMP
GM-6100F
for the maruti swift (small internal volume) i think 2~3 W rms / per speaker for mid / high frequency is enough for fairly loud listening. 5W max or peak.
For bass and deep bass (subwoofer) 15 ~ 25 W rms should be sufficient.
NB: rms = continous rms values.
For a car, more imporant than the components is how you set the equilizer. Try to find a component person to do this. My friend got his deck serviced, and that idiot had set bass and treble to +6 !!! :O And as my friend only has two rear coaxs, it sounded like a rickshaw! :P
yes pioneer amp r better but they r also pretty expensive for nearly the same sound,,and yes ovals are better in the rear if u wat dat extra bass without the sub i would say go for the :-
pioneer deh-6850- 9k
sony 4way amp -5k (not to sure mabe less or more)
Jbl Oval rear -5k (depends on dealer to dealer)
dats more than enough so very gud sound n in front u can put tweeters.....pioneer original hardly 500 or sumtin
u will have a rockin system like i do (if tuned well)heheh
happy listening
Guys Finally the Audio System is in place.
Got the following.
Pioneer DEH- 4850 Rs 6500
Link:- http://www.pioneer.com.au/car_entertainment/cdtuners/dehp4850mp/index.html
Sound Stream Rear - 3-Way - 120W RMS - Rs 5000 [EDGE Series EGS6.9]
- Zolon Coated Low Resonance Baskets
- Black Zicronium Plated Injection Molded Cones
- TPU Rubber Surrounds
- High Efficiency Polymide Dome Tweeters
- Aluminum Voice Coils
- Swivel Pole Tweeter Mount
- Gold-Plated Terminal Connectors
- Rubber Magnet Cover
- Ferrite Magnets
- Grilles and Mounting Hardware Included
Link:- http://www.soundstream.com/intl-speakers-edge.htm
Sound Stream Front - 3-Way - 50/80W RMS - Rs 2900 [Xtreme Series XTS5.2]
- Black Zicronium Plated Injection Molded Cones TPU Rubber Surrounds
- Chrome Front Back Plates
- Ferrite Magnets
- Grilles and Mounting Hardware Included (except XTS3.5)
Link:- http://www.soundstream.com/speakers-xstream.htm
Silicon 2-channel 300W Amp for the Rear Speakers - Rs 3900
Sound Quality is amazing , I spent money on the speakers and lowered money
on the Pioneer Unit , orignally wanted a DEH 6850 [Rs 9K] which was
awesome having a OLED Display but wanted to save some money and
accomodate a Amp so went for the DEH 4850.
COOL.. dude.. Congratulations .. We have identical systems minus the amp.. Told you about the speakers.. I'm just in love with them !!!!
