Suggestions required on Samsung cativare complete body protection
surinder1508
Contributor
Guys I need an advise for protecting my Captivate from scratches n G shocks in minimum possible size n weight cause the whole thing is going to remain in my pocket all day. So some gel case or any other soft case type of thing is what I'm looking for.
Regards
Surinder
I use Otter Commuter case. This case completely covers the back, sides, top and bottom with pre cut holes so that you can still use headphones, usb and also buttons without removing the case. The camera can also be used with cover. Only you have to remove the case when you need to remove the battery or sim card. Also it is dual layer so you put soft case and then insert it into hard case. With this you get dual layer protection. When I travel I use two layers, when I am at home I just use the soft case. They also keep the phone in scratch less and good condition.
It fits on my pocket with ease. It does not add bulk to its weight. But also since it is tough, you will be confident that the case will help your captivate during the fall.
Here is the product description and pictures:
Samsung Captivate Commuter Series Case // OtterBox.com
