Laptops Swapping power adapters between Macs?
My wife and I both have 2011 Airs, and I just ordered a Pro 13". The power adapters are of different ratings, I think. They also have different magsafe connectors, but you get an adapter.
With an adapter, will it be safe for me to interchange the power adapters?
yes, absolutely
I have the exact same scenario as you 2 -11"era and 1 13"er with the new and old magsafe connectors and an old to new adapter
So, can the Air adapter be used with the Pro AND vice versa?
Where did you buy the adapter?
It's not Air -> Pro or vice versa
The adapters are for converting old magsafe connector (thin and long with wire on side) to new (fatter with wire perpendicular to centre)
There probably will be something the other way round too - i just have the old ->New as i have 2 of the former
Think I picked it in the UK but should be available locally too
