PC Peripherals System Starting Problem
nanda
My Config:
Q6600
Biostar TP35D2-A7
2 x 1Gb Transcend
Xfx 8600 512mb
Viewsonic VX2255Wmh
CM 500 Extreme
My Problem: The system didn't start (POST) without atleast 10 restarts.?
Sometimes it starts but hangs on the BIOSTAR LOGO or Windows XP LOGO Screen?
The m/B have two LED'S to test the Memory and VGA it doesn't blink all times, it blinks it will start to work. Please HELP!!!!!!!!!!
What's the problem , Please HELP!!!!!!!!!!!!!!!!
PSU gone for a six. Or the motherboard is completely fried. Take your pick. (Most likely the PSU is ruined, but a bad motherboard can do that to a PSU...)
First try as SIDHU said and later chk with PSU (changing it).If no results then try changing the rams (or even only with one ram).Also chk for any burn smells in the Mobo or in the PSU.
Hope ur components are not fired
Mostly a problem with your Motherboard. However your system hanging while booting may also indicate a RAM problem.
Unplug everything and replug, or ideally take out the board from your case and try, something might be making contact and shorting in the case!
nanda said:
Thanks!!!!!!!!
BUT the PSU Works fine (Fan Runs) & cabby and processor fans are working, Keyboard LED's also fine.
Its not that way .It may be supplying required power through molex cables but not may be with the mobo cable (even the processor fan runs).
I hope u got me .Anyway if u wont suspect the PSU then the possibility will be the mobo .Have checked it for any burn mark or smell
During POST do you get a normal single beep sound or something different?
I suspect the RAM,try to fit it on the other slots.
