Thanks to all for all ur wonderful replies & time.
Just restored my registry to previous days.
Msconfig shows no threatning entries.
But my PC is working wothout AV.
And i dont visit any sort of illegal sites nor use any sort of P2P Apps from where Viruses can enter.
Also amoungst the sites i vist are all tech sites , so dont know what exactly went wrong.
Let me describe u the scenario.
- My PC was offline , i dont have IP address settings for my Cablenet Connection
- I was copying a Linux 700Mb ISO file from drive C to my last drive F.
- When suddenly after 60-70% of the transfer completeled BSOD appeared.
- I immediately clicked escape key and then Windows appeared.
- After i rebooted my PC some files related to Norton & Sygate Per. Firewall were
not found , on checking Spybot & AdAware also they were also not working.
So this is what happened.
Later i removed Norton,Sygate,Adaware,Spybot
Installed Syagate & Kaspersky AV
But kaspersky brought my PC to its heals
So removed it currently i am having Sygate Firewall as my only protection.
And my PC is booting fine , but everytime i start my PC it scans disk in DOS mode
and says fixing long file names.
Then the PC boots UP fine & then i connect to the ISP & here i am now replying on TE.
But still i will format my C Drive after backing up all ,y data from my friends place after
doing a complete scan.
Also wanted to tell you that
I have a P3 - 450Mhz CPU , ASUS P2BVT [intel 440BX] Chipset , 256Mb SD Ram
And the problem is the new HDD it keeps corrupting the C Drive after one or 2 Months
So far i have had no clue why this happens.
I am using my HDD in 32GB Clip mode.
When ever the data in my last partition exceeds 85-90% of its storage space
C Drive becomes corrupt.
Guys do let me know whats wrong exactly.
After finding i have found that not only my security softwares but some other
programs are also not fuctioning.
