PC Peripherals Test tones for testing speakers / sound card
PoBoy
Juggernaut
Does anyone know where I can get audio test tones, for example only left channel, only right channel, 30hz, 250hz etc. This should be pretty useful to test speakers / sound cards and the audio system setup on a PC.
If u have a creative sound card then with creative surround mixer you can test your speaker channels.
My Creative SBLive Value 5.1 has it .
Check if this is what you are looking for...
http://www.audiotester.de/
If you just wanna generate sound of different frequencies, just use foobar. In the open location dialog, enter
tone://<freq>
where <freq> is the frequency you wish to generate. (replace with 20 for 20Hz or 20000 for 20 kHz)
well if u have a good card u shud get a demo disc,i have a dvd audio demo sampler disc which is jus mind blowing:P
and a sampler disc,showing me effects of thx,dts,DD,eax advanced hd n stuff
wut kind of card/speakers r u looking at here
Actually, what I thought they might be useful for is things like testing the freq response of your sound card + speaker ( like can you hear a 50hz sample on your system ? ). Also, it may point out errors in set up ( left speaker connected to the right ;-) ).
I did find some samples here :
http://www.eminent-tech.com/techsuppt.htm .
