panky.killer
OS:- Vista
Ram 2gb
Problem:-
1.When ever i plug in to the power cable when system running its goes blurr like RAM issue. hole spot spot comeing up on screen and lappy hang.
What i had done to slove it.
1.i had check with another ram this is not ram issue when ever i pluged in 4 the power its goes hang and gives error
2. install the windows xp and used the power bt here its work very fine and dose not gives any issue.
3. now trying to install win7 bt is not getting install
its goes smooth with boot option then
its ask to load the disk.bt is nt like tat i never used to install it bt i think the cd-dvd rom issue is there i had googled it and found no clue abt this error
Final verdict
1.i am not able to reinstall the vista its need full battery i had try twice and fail to install the full OS.
2.i used Win 7 bt no use clueless about the issue what i am faceing.
3.win xp i can use it. bt i need to slove problem.
I need help from here.. as it is problem i had seen it 1st i had diagnostic uptill this.and need help.
:huh:
i had install xp and its working perfectly fine bt issue is no driver avaliable for the xp and vista is giving same issue.
i am finding the sutitable drive for it
i tried to install vista bt same issue is comeing up
Ram 2gb
Problem:-
Final verdict
:huh:
