Hello Guys,
Iam planning of buying a TV card and also DVD burner.
TV Card :
Does internal ( those which use processor ) TV tuner cards affect the PC during
rainy seasons and whenever there is a leakage in the Cable ??
Is it better to use TV to VGA converter means the external TV tuner box ??
If internal is preferrable ?? whether to go for USB or the PCI interface .. ?? performancewise vs pricewise. Which are the best brands with model no.
And for DVD burner .. i would be going for BENQ 1640 . How much does it cost in
DELHI or NOIDA ???
Thanks in advance !! :hap2:
TV Card :
DELHI or NOIDA ???
