two thrones display problem
zero_cool
Forerunner
hey guys
i know this game is way too old now but it still has a charm so i am leaning to play it
i have installed the game and many times i encounter a sudden blinding light on the screen and i only get over it after i pass that certain point
the light is totally blinding and it is impossible to play then
i have installed the game on my other system which is without a card and it works without a problem there just lags a lot because of the absence of a card
can anyone help me with this
As soon as I receive your telepathic signal about the configuration of your system, I will certainly reply..... :)
ah
you dont need to use your telepathy sense to receive them
this post should do the job:P
i have a
core i5 2500
ud3r
gtx 460
8gb ram
antec true power 650
windows 7 home premium
my other system
amd 5400+
asus m2n-68-am-plus
2gb ram
windows 7 home basic
non branded 450 watt power supply
@zero_cool: I am afraid I can't be of much help here but during 2008 when I tried playing this game on a 8800GTX and a Dell 2208WFP, there was no option to set the resolution within the game to 1680x1050. At a later stage, I got stuck due to this issue since I couldn't bounce off those switches on the wall and the prince would simply fall down.
I am not sure if Ubi has addressed this issue later with a patch to support widescreen resolutions.
None of these games received an official Widescreen patch. There were 3rd party tools for WW and TT, which enabled Full HD support.
A screenshot would give us a better idea.
solved that problem mate
it was due to some error with the graphics settings
i had to lower the settings and it worked
this is quite amazing as i was about to report a similar problem
the prince keeps getting stuck on the chains or just falls off
seems this game was meant to be played only for a specified era
thanks for the response everyone
