Dear friends i need your help regarding a problem that i am stuck in.
I have a ryzen pc last month i had to move away from home so i decided to wrap the pc in a plastic sheet to save the components from dust moisture etc so i wrapped completely taped the entire pc air tight completely and put in almirah after one month i opened the pc i found all over cabinet surface has plastic sheet smell and the cabinet is having some unusual patterns from outside seems like greyish lines i switched the pc it works perfectly. Now i am confused is it a cause of concern or not kindly help me friends and thanks in advance.
