Hi,
I have a bsnl wireless router wga3002g4 (5 watts). i want to connect it and a 10ish watt cfl to a ups/inverter during powercuts.
not sure a conventional ups would help since they shut down in some minutes (my powercom ups does). i want something that will run for a couple of hours to run with my lappy, as long as the loadshedding continues. so probably an inverter or a customised solution.
i think a 500va inverter would be an overkill for a 10+5 watt use, so want something cheaper, if it is available, ie. (i live in pune)
do any one of you know of something? thanks in advance.
