enthusiast29
Level I
Hi,
I have a PC with 750W PSU and dual monitor setup.
Currently I'm providing it power through my inverter which is 900VA (756W max) sine wave, you know where I'm heading with this...
So obviously when I run something heavy and power cuts, the inverter shows heavy load and trips the whole circuit for the house.
On idle/light loads it's fine but since this is my personal use + gaming machine I don't want it to have an unsafe shutdown.
Please suggest ideal UPS for this so that I can at least close my game and put the system to sleep mode (or power off) until power is back.
EDIT: TL;DR, my solution is here. This is for me personally, others may like some other approach.
OR
Should I upgrade the inverter capacity to a higher model such as 1500-1650VA? My doubt is will it be able to switch fast enough when my PC is on load?EDIT: TL;DR, my solution is here. This is for me personally, others may like some other approach.
