CPU/Mobo URGENT HELP NEEDED.....Opteron OR Xeon for 3ds MAX...
ragsbava
I am building a workstation for a friend who will be using it for modeling and rendering building walk thoughs and also for compositing work in combustion. I am planning for a Quadro FX till 15k, 3 GB of ECC Memory.
The main confusion I have is Opteron or Xeon, Quad or Dual core and which mobo and are socket AM2+ n LGA 775 workstation processors available in India ?
I need help on Processor...Mobo...GFX....
I have something in mind but way to confusued and dono if v get that here easily :ashamed:
1. Fastest will be a dual xeon system. Most vfm will be multiple C2Q systems.
2. He'll need more ram. 4gb is the starting point. And obviously a 64-bit OS.
3. Haven't used a quadro, so can't comment on whether the price diff over a geforce justifies the extra cost.
^^ ok any info about rate and suitable lga 771 mobo availability in india ....
anlother thing i cant import anything via KMD as my friend is too paranoid about it...if tht was the case i would have assembled one long back...here all dealers are mOrons....sell bhajipala....
On a single machine or even on a cluster of 4, ECC RAM is absolute waste of money. You could go for C2D and non ECC RAM and get the same perfomance/stability...
If you want to go for professional cards, Quadro FX570 is a good budget card at a decent price.
ok ECC ram out then will C2Q till 15k be better than opteron n xeons in same price range ? cause he ill be duing professional work on the machine...
Ok guys i have shortlisted following parts....:cool2:
Intel C2Q Q9450 cooled by TRUE120
ASUS P5Q
Transcend 800MHz 4X2GB RAM
nVidia Quadro FX ( till 15k ) ill decide tomorrow after i ahve a word with my hardware guy...^o
CM690 with Corsair VX450
Dell 22" SP2208WFP
WD 640GB
PLEASE COMMENT ON THIS :tongue:
i really doubt he is going to need a quadro card for doing walkthroughs ...unless he plans to get into poly intensive character modelling ...for an entry level quadro card he can get a mid range card and be very happy with it ...speaking out of personal experience
ASUS P5Q
Dell 22" SP2208WFP
WD 640GB
Nice config :) Check if the q9550 is available.
