CPU/Mobo urgent help required regarding amd mobo and proc
amd3000
Contributor
Hi,
Friends i am new to the AMD processors, all i ever heard about AMD processors are if you have a money constrain then only go for AMD, but i am now planning to upgrade my confi and i need it to be AMD, my needs are more of work related than gaming.
Here are my requirement and budget.
* Budget is max 15k
* Including ( Mobo+proc+ram )
* I do not play games much ( i have ps 2 for that ) but some times i do like to play the latest games but not in high config.
* But i like to watch Hi-def movie and animation and as i am using samsung jet i will the computer to convert them into div x format so that i cn play them in my phone.
* I need to work on virtual machine also ( for programming and networking needs ) so plez suggest me should i go for high proc or ram.
* I have ATX cabinet ( smps 400w ) so vl i need anything else if i in future add any graphic card.
Components i already have:-
*Samsung TFT Screen ( with touch panels )
*TVS Gold Keyboard
* Cabinet ( ATX, company i don't know )
*Speakers 2.1 ( creative )
* UPS
i need the specifications urgently, any help appreciated.
Processor: Athlon II X4 620 - 5.3k(quad core :D)
Motherboard: Biostar TA790GX A3+ - 6.5k/Gigabyte 785GMT-UD2H - 5.9k
RAM: Transcend 2GB DDRIII 1333MHz - 2.6k
SMPS: Zebronics Pro(Real Watts)-350W - 1.5k
This should be around 15-15.5k~ and is more than enough for your needs+ is future proof with quad core, DDRIII mobo, RAM
Reactions: 1 person
Thanks for replying so fast kartik and anubis, is the smps reallh required as i mentioned i have smps (maybe of iball) is it worth investing in a new smps . Also, is 2 gb ram enough for my needs( converting and watching video , virtual machines, casual gaming ).
i have heard about phenom 2 processor.. how is it , should i go for that, If yes then which one...please suggest...
thanks again.
Your better off with the smps he suggested, at that budget the stuff karthik suggested is the best you can get, go for it.
which motherboard is good, gigabyte r biostar, as i use computer very much almst 24x7... no worry about electricty its always available and it rarely fluctuate... [:d]...
