ashish
Forerunner
help my pc is freezing unknowingly.
during any activity the system freezes and then i have to power it off via cabinet on/off button ot else reset.
my pc specs
amd phenom 550
biostar 790 128m mboard
2gb jetram 800mhz
250 seagate sata
8600gt
intex pci lancard
i was doing some networking p2p and ics with my laptop and everything went ok bt the freezing problem started when i was copying/ virus cleaning the laptop through my pc.
I thought it was something network related but now its happening frequently dont know why. cant get the exact cause.
My cpu temps are very normal, 34c idle and 38c on load so no overheating.
I viewed the event viewer, it is showing maximum times the following events repeatedly:-
In Application:
type: warning
event id: 1015
TraceLevel parameter not located in registry; Default trace level used is 32.
In System
type: information
event id: 1001
The computer has rebooted from a bugcheck. The bugcheck was: 0x40000080 (0x89db18b8, 0x89b48378, 0x89b37f7c, 0x00000003). A dump was saved in: C:\WINDOWS\Minidump\Mini081309-08.dmp.
rest events are normal.
i dont get any bsods screens and have no problems while gaming.
I have latest eset nod32 and scanned my pc but no viruses or anything found.
my pc specs
amd phenom 550
2gb jetram 800mhz
250 seagate sata
8600gt
intex pci lancard
In Application:
type: warning
event id: 1015
In System
type: information
event id: 1001
