Urgent : Water Purifier for Home
What would be the maintenance cost(s) of one of these upper end Kents, like replacement filters and certain other internal parts, which need to be replaced at regular intervals. We are currently using Purit classic and it costs Rs.835 for 3000 litres of filtered water, no electricity needed.
I Recommend Kent Pride +
In Kent Grand +.. After 24 Hrs In Water There R Chances That Bacteria Will Born Again.. Also UV Kills The Bacteria and do not Remove it from Water.. Also After 700 Hrs.. U Have to Change ur Filter Compulsorily.. If U Dont After 48 Hrs.. Machine WIll Stop.. Go For Pride +
I Bought It in Jaipur for 13250 Rs Along with Dat Additional Filter Placed before Machine and 2nd Year Service free of Charge Mentioned on the Bill..
Water purifiers are installed on the basis of quality of water supplied at your home. Get your water checked by the sales person coming to your home by water purifier co.
If the TDS is more than 600 then get a RO and if less, get a UV based water purifier.
If you are going for a RO, get a simple RO with pre carbon & post carbon and sediment. Keep in mind that you should get a good co. of RO cartridge like filmtec.
all other factors like TDS controller etc by kent or any other co. is just their market strategy as RO itselfs pure the water upto 0.0001 micron.
