- Expected Price (Rs)
- 1599
- Shipping from
- Chennai
- Item Condition
- 5 out of 5
- Payment Options
- Cash
- Bank Transfer
- Purchase Date
- Aug 14, 2019
- Shipping Charges
- Included in cost
- Have you provided two pics?
- Yes
- Remaining Warranty Period
- 9
- Invoice Available?
- Yes
- Reason for Sale
- Not needed. I got this for personal use but ended up not using it beyond testing it out.
High speed multi-format card-reader. Got this for personal use but ended up never needing it. It's just lying around. But it's a fantastic product, difficult to get in India.
Manufacturer Description:-
ZEDELA USB 3.0 superspeed multi-card reader versatile transfer SD card hub adapter solution between multi-format memory cards and PC or Mac.
Plug and play on the computer or laptop equipped with standard USB 3.0 port with most modern operating systems, including Windows XP/Vista/7/8/8.1/10, Mac OS, Linux.
Card Slot Compatibility (Read and Write on 5 cards simultaneously.)
*SD slot: SD/SDXC/SDHC/Extreme I III SD/Ultra II SD/MMC
*Micro SD/TF slot: Micro SD/TF/Micro SDXC/Micro SDHC/UHS-I
*CF slot: CF I 3.0/4.0 /Extreme I III CF/Ultra II CF/HS CF/XS-XS CF/CF Elite Pro/ CF Pro/CF Pro II.
*MS/M2 slot: MS, MS PRO, MS PRO-HG, MS XC DUO
*Special technology card slot:MS PRO DUO, MSHG, XD, XD1.21
Super Speed on Data Transfer
Support super faster data transfer up to 5Gbps through USB 3.0 interface -10X faster than USB 2.0, transfer HD movies or files in just seconds.
Compact Design
Slim card reader easy to grab and go. 21.6in data cable tail would reduce stress on the USB port on your computer and won't affect the use of adjacent ports.
Top Technology
Multi-shield tin-plated pure copper core, sturdy exterior and heat-resistant connectors ensure high data transmission efficiency and ultimate durability and effectively avoids over-current, over- voltage,leakage,short circuit,clutter.
Specification
-Compliant with USB 3.0 standard, support speeds up to 5Gbps.
-With 7 card slots: Micro SD/SD/CF/TF/MS/M2/XD
-Compatible with Windows XP/Vista/7/8/8.1./10, Mac OS, Linux, etc.
-Plug & play, no driver installation required
-Size: 71.9mm/2.83in x 48mm/1.88in x 12.8mm/0.5in.
-USB 3.0 cable length: 0.55m/21.6in.
Compact Design
Top Technology
Specification
