raksrules
Oracle
I have this BCK-08 Bluetooth which looks like iPod shuffle. Check below link to see how it looks.
This thing has the same port acting as charging port and audio earphones port (so i cannot charge and use it both simultaneously).
Now it came with a USB Cable for charging which has a 3.5mm jack. This cable has gone bad and refuses to charge the bluetooth anymore. The cable was already broken but i was somehow still able to charge by "adjusting" it to proper position but it seems to have broken beyond repair now.
Need to buy a new cable to charge this device now. Can anyone suggest where i can buy one for cheap and it has to work guaranteed.
Bluetooth Link: http://www.amazon.ca/BestDealUSA-Universal-Bluetooth-Earphones-Charger/dp/B007XOXNSC
I checked on ebay.in and there are those iPod shuffle charging cables available but they are many a times not even compatible with different generations of the shuffle so i am confused which i should be buying.
Also it would cost like 300 Rs or more from ebay.in to order that cable and there is no guarantee it will work. Too much risk.
Last option is to buy a new bluetooth device (probably Bluedio I4) which will cost about 1K INR. Don't need any fancy BT.
But first i need to see whether i can get this cable for cheap before buying a new one. This existing one although in not great shape still gives me good battery life.
