PC Peripherals USB HUB - 4 Port - help!
Haddock
I'm in need of a good quality/performance USB Hub, pls recommend under Rs.500. ;)
Currently i own this -
I want a HUB similar to that, i.e. all USB Ports facing front.
or like this one
I want to integrate that to my PC Table, so pls. recommend a brand/model that can last really loong.
PERFORMANCE DIFFERENCE b/w m/b port & Cheap USB Hub
Transcend Pend Drive "File Benchmark" using HD Tune
Directly plugged to m/b USB port & Internal Card Reader (negligible difference)
Plugged into chinese make 4 Port USB Hub.
So far, i've seen BELKIN branded USB hubs at ebay, but are they really worth 800+ bucks? :O
Is AMKETTE brand good in USB Hubs?
two products are there -
1. eBay India: AMKETTE - Hi Speed 4 PORT USB HUB (item 150528584440 end time 10-Dec-2010 16:42:52 IST)
2. eBay India: Amkette High Speed 4 Port USB 2.0 Turbo Hub + Bill (item 370464866938 end time 14-Dec-2010 11:50:33 IST)
does that TURBO really works or is it just a gimmick? :p
can you spend 2K ...the roccat one looks great and doubles as a cable manages as well !:)
looks like a figurine :D , if you have that kind of taste you will love them :)
considering ur budget amkette is not a bad brand its not just great as belkin or roccat i suggest u go with amkette as ur buget dosent permit u to buy belkin or roccat apuri.
